UCA and LCA bolts
MD
I need the part numbers for the OEM bolts that go in upper control arms and lower control arms. I believe there is 1 that goes on each side in UCA and 2 that go in each LCA.
I bought a set of Ironman UCAs to replace the original ones and my mechanic was unable to remove the existing bolts as they are completely seized. He said he may have to chop them off to get the original UCAs out. He said these bolts are also used to do alignment afterwards.
I also bought complete set of OEM LCAs and need to buy bolts for them also. If you have part numbers for these that would be great.
I've spent considerable time searching all over the web but can't seem to find the right ones.
I just bought all these as well. This should be everything you need.
Long UCA bolts: 2x 90105-A0095
UCA nuts: 2x 90080-17208
(There are also 4 washers, my Dobinsons UCA's came with them and yours might be salvageable, they are part # 90948-02177 if you need)
LCA toe adjustment:
2x 90119-14120
2x 48409-60020
2x 48452-35020
LCA camber adjustment:
2x 48190-60020
2x 48198-60011
2x 90179-14069
I was putting these part # in parts.lexus.com and some of them are only showing for GX460. I hope they work on our model as well? Have you already used them on yours and they worked?
That's weird. I've already installed the LCA parts and they were the same stuff I took off. Upper bolts are still sitting on my desk and I've only test fit them to my new UCA's, but I picked up everything from my local lexus parts dept so I expect them to work.
