After coming back from Moab I was motivated to upgrade my air compressor capacity based on the performance I had see from the Puma and Superflow’s air compressors the Copper State Cruisers were using. Norm bought a Puma (see his Puma thread) and I bought the Superflow MV50. My plan was to mount two MV50 on their side so they would fit in the foot well behind the passenger’s seat, thereby not using any valuable cargo space, which is scare in a 74.
These compressors are wired in series on 24 volt to allow me to run two 12 volt compressors without upgrading my voltage converter which has a maximum capacity of 20 amps. They are wired from the battery with marine 8 gauge wire (closer to AWG #6 gauge) through a 40 amp marine circuit breaker (located beside the batteries) and through a 24 volt solenoid (Cole Hersee continuous duty 85 amp solenoid part #24124) through each of the compressors and back to common. I scrapped the compressor switches and internal relays. I installed a standard flip switch between the two compressors which activates the solenoid and the two compressors.
