Turnkey 5.3L with 6L80e options
Ft. Worth, TX
Researching a complete swap with crate 5.3L mated to 6sp auto with all preprogrammed ECMs...
Anyone know who sells a complete turnkey ready to go setup like this?
TIA!!!
Dont know of a turnkey crate engine setup can also try Brian at bd turnkey engines he may be able to help he deals with used engines doesn't deal with transmissions tho but may have some info in his brain.
Gm sells new engines. Transmissions can be bought anywhere I believe. Independent transmission controller shouldn't mater if looking for stockish tunes. The tcm-2650 is the only controller working with the 6l80/90 at the moment if you do not want stock setups.
It is best to buy from gm if you want new not rebuilt/used.
Pacific fabrication and mars sell turn key tested low millage used engines. Mars also has transmissions. Car-parts has used stuff you can find.
I the engine in mine came from Pacific fabrication I believe and I think they sourced the transmission also. I will have to check the receipts from the PO. Not sure anyone has a truly turnkey set up exactly
