Turn Signal Flasher Relay
McCall, Idaho
So here is an odd on. I have a relay 5 pin in my 71 🐷 and it makes a rattling sound when running at times in 1stand 2nd gear. Literally sounds like a rattler! Now, it functions okay... but it is annoying! Any suggestions on what gives, possible fix or even replacement. Below is the relay. I’ve searched and cant find a replacement readily available. Thanks!
This lil piggy is nearly 100% original... so nope, old lights still in. I wonder if this relay also assists the Speedo
Speed marker relay! What ever that is.... lol
Looking at the wiring diagram it controls a valve, taking a wild guess that valve is on your vacuum advance and pulls timing once you hit a predetermined speed, I would disconnect it and go for a drive.
