My 87' RHD BJ70 turn signal lights do not work. Fuse and flasher are good and the hazard lights function correctly. I measured the continuity of the connector for the turn signal and hazard switch and found the problem of no connectivity between pins 2 & 7. The Toyota manual indicates the following:
It appears it is not as simple as stated above, to me it looks like the steering wheel must come off first and then the turn signal switch can be slid upward and removed, the turn signal switch seems to fit around the steering shaft, it doesn't look like it comes apart to be removed...am I missing something here?
