Some of you guys with LJ7x and LN130's might find these videos very interesting. To my knowledge no one has every really taken things this far with the motor. I've always wanted to but never had the time. These guys get very techincal with the motor and adapt an early 1KZTE piggy back to the 2LTE (they have basically the same ECD system).
The video images looks like they're stupid, but they're actually quite good.
They share a lot of very interesting info - Ben guy is very tech/tuning savy. One interesting point is the 2LTE fuel maps put out the most fuel at 10psi and the computer starts pulling it back from there, ultimately creating a CEL at around 15psi. So those running a MAP Sensor 'bleed valve' should set it so the ECU only sees 10psi max. Without having a piggy back tuner, you can use the spill valve and fuel resistor to tune fuel, and the timing resistor to tune timing. And of course manual boost controller to set boost pressure.
2LTE Baseline Dyno:
Unichip and tune while driving:
2LTE Baseline Dyno:
