Tundra wheel compatibility
Ottawa, Ontario
I would like to purchase these Type A (42601-0C070) steel wheels from the current Tundra to use on my J250. Has it been determined that all these wheels are cross-compatible?
Bolt pattern is the same but not sure about the center bore and stud specs on the LC 250.
42601-0C070 has a center bore of 96mm which is standard for all Tundra wheels from 2023 onward. Same for 2024 sequoia onward as well.
TNGA has seemed to make all wheels almost the same specs across all body on frame vehicles from Toyota except the LC 70 seems to be the outlier still.
My research is suggesting both vehicles are 95.1 CB and studs are M14x1.5. Width and offset should be the same or very similar.
Oops. Thanks for the correction. It is 95.1 but there will be some positive tolerance.
