HungryMedic
That doesn't look too hard... What could go wrong?
Matt, we need to design those rear tube doors
dontcha wanna?
dontcha wanna?
dontcha wanna?
Metal tech designed a rear tube door for the FJC that they were supposed to put into production. I saw pictures but it was a couple of years ago. Not sure what happened.
Probably same 2 problems we have, just on a larger scale
And when I say rear tube door, I'm talking about the one that the spare tire hangs on, not the suicide doors. The suicide doors would require some sort of interior roll bar and seats with four point harnesses.
your exactly right Jonas, my idea involves (get ready for engineering language) a big honking vertical tube, that latches where the suicide door does. Then you have two bars spanning the inside of truck between these 2 vertical bars. Those bars are what the front tube doors would actually latch to.
The idea I have is really just a skeleton version of the stock doors, not just a bottom half like the front tube doors are.
Why not make a "tube door" that would be the same shape as the full suicide door? You could add the latches as necessary. If you go with harnesses up front, you would be golden! Structurally, it would keep the FJC in shape and keep it from twisting.
.....and, thank you all for allowing me to moderate.
Might as well tube it out and save some time
dontcha wanna?
