Just wanted to document what happened and what I am doing to hopefully remedy it.
Noticed the Sequoia was shifting a little hard for all gears the last two times I was driving it (~ 50 miles). It was just slightly noticeable - when previously transmission shifts were completely unoticeable. Otherwise the truck drove fine. Checked fluids - engine oil looked good and was at a normal level; transmission oil looked okay on dipstick but was really high; coolant in radiator was half a gallon low.
Without thinking much I filled up radiator coolant and noticed oily residue.
Symptoms seemed consistent with a leaking transmission cooler in the radiator. Decided to diagnose issue by draining radiator - definitely something oily in there, wouldn't quite call it the pink milkshake. Next drained the transmission and got the milkshake. Collect 5 to 6 quarts when I would normally get 4 quarts from a transmission drain.
The radiator was relatively new (Denso, 221-0518, replaced on 2/2023 when I was doing the timing belt, purchased from Amazon). Not sure if this was a 1 in a million flaw for Denso radiator, or if it was a knock-off sold through amazon (visual inspection when installing - it looked pretty decent), or really hot weather (southwest Arizona) was a factor, or all of the above or none of the above.
My plan is to replace the radiator (purchased Toyota radiator from local dealership for $170, 16410-AZ012, surprisingly inexpensive), flush the coolant system and transmission, bypass internal transmission cooler, and replace the external transmission cooler with a Hayden 698 transmission cooler.
I will update as I progress through the work.
