there is a knock in my 80 fj60 driveline that is noticable when the load changes direction (reverse to first, downshifting to accelerating in all gears) that sounds pretty bad. i got under it and the u joints are all tight, the front and rear driveshafts are tight to each other in 4 high and low. there is a slight amount of play in the front and rear diffs but not much. when i turn the driveshaft by hand with the tcase in neutral there is no noise, but with it in engaged in 2 or 4 there is about 20 degrees of play and a noise. the tranny in gear or neutral does not seem to effect the problem. i'm not familiar with the internals of the tranny or tcase...anyone have any ideas?
