There are adapters to go from a GM auto to the HF2A/V tcases..
There are adapters to mount a NV4500 manual to the 1FZFE but nothing for the transfer case to the NV4500...
I'd prefer a properly built GM auto as getting a manual to handle the power and mount to a T-case may not be possible.
You cant put a t-case on a pony car tremec, the NV5600 is giant and is obsolete (mercedes 6 spd behind diesels now).
I prefer an auto anyway for desert running and just street driving. The big truck manuals are bleeping huge and balky shifting.
So I was looking at a friends mopar that had an interesting transmission. It was a TH400 bolted to a hemi. The bellhousing of the TH400 was cut off and an aftermarket SFI Approved (scattersheild) bellhousing is bolted on using longer transmission pump bolts. It is called an ultra-bell.
An installation here.
Changing Th-350 bell-housing to Ultra Bell - Chevelle Tech
There is no toyota ultra bell but the bell housing on my A343 unbolts and is secured by a ring of bolts just outside the trans pumps ring of bolts.
So I am thinking why not cut the bell housing off of a 4L80E then make a plate to bolt to the pump that will mate with the A343 bell housing..
Once again I find I am not the first to have the idea. Some supras come with the A343 and they got tired of broken sprags. So SoundPerformance did just that. They cut off the 4l80E bellhousing and bolt on a CNC adapter plate then bolt the toyota transmissions bell housing to the adapter.
Supraforums.com - View Single Post - It's HERE!!!! 4L80E for the Supra.
So now I need to see about getting just the adapter plate and tq converter setup. A 4l80E can be built to take over 1000hp.
I will look at the total cost of this. If it is not to bad I will stick with turbo charging the 1FZFE. If it gets spendy I think I will dump the 1FZ-FE and put in a built LS2 Backed by a 4L80E..
So I am thinking why not cut the bell housing off of a 4L80E then make a plate to bolt to the pump that will mate with the A343 bell housing.. Once again I find I am not the first to have the idea. Some supras come with the A343 and they got tired of broken sprags. So SoundPerformance did just that. They cut off the 4l80E bellhousing and bolt on a CNC adapter plate then bolt the toyota transmissions bell housing to the adapter.
would not like the manual shift auto a PCS trancontroller can go in.
