trans. filter change PROBLEM UPDATE
Hello again,
New problem...I added the fluid to the engine the best of my ability to guess and now there is approx. 7.5 quarts of trans. oil in the transmission.
The vehicle has been running idle just fine with the manual throttle control next to the steering wheel. But, as I added the fluid to the transmission little by little, the engine idling became rough about 10-15 minutes later and then eventually stalled out.
Now it doesn't want to start! I wait about 5-10 minutes and try to start it and gives a big voom and sputters unconscious again.
The longer I wait the better the chance that the car would stay alive. It actually did start and ran rough for about a minute.
Another note too is that there is a light on the automatic shifter that says "AT oil temp" I think, that is lit up red.
Does that mean anything?
Question to myself is I'm thinking that the trans. oil is filled too much. Could be a possibility? If so, I'll drain some out.
Any help would be greatly appreciated. I need to get this thing started again. It ran fine before I added the extra quart and a half to the transmission.
Thanks.
chrisusvi
