Tranny question on '00
Louisville, Colorado
Greetings all. I'm a IH8MUD virgin, and a new 100 owner to boot (its a 2000 w/ 50K on it). Very happy so far, but do have one nagging concern. Sometimes when shifting into D from R, the tranny makes a dull "thud" noise. It seems to drive fine otherwise. I'm not used to automatic trannys, and I wouldn't give it a second thought except the car has a 30-day warranty and I'd rather have the dealer pay for fixes now than me pay for it next month.
Any words of comfort or concern are appreciated...
I also have a '00
And I do not think mine has ever made that noise. To me, that would be a concern.
I'll check mine out later this morning to verify.
Have you checked the fluid level in the trans? I would also check the driveline/u-joints and grease them. But go easy with the grease gun and don't over do it!
That's what I figured it was. It's only when going into drive from out of R or P. Doesn't slip or knock when shifting at least on mine.
Checked mine. There is a small "thud", but it's no different than any other automatic truck I've driven.
ShottsUZJ100 said:
How do you know it's not the normal driveline slack reversing directions?
Gets my vote too. I'd take it and have the driveline lube points greased. May quieten it up a little, plus it may be overdue.
Ditto here. I was guessing (hoping) it was just slack. Thanks for the feedback.
Mine does the same had the driveline greased still does it I think that it could maybe be the u-joints now I will have them checked when I can get her off the road for a day.
I know there were some tranny problems on the early 100s addressed by a TSB. Not sure if the 2000s are included- maybe someone else can chime in.
Are you getting frisky again? :D
Calm down AC. :beer:
I'm sure this the typical driveline slack noise that's found in both the 100 and the 80. ;)
No frisk involved, sir. Just trying to help...I forgot what was in the TSB...anyone here remember?
medtro said:
Regardless of what it is, why not have the dealer fix it while you still have the warranty?
Because frequently the dealer "fix" is worse than the problem, and/or they cause collateral damage / other problems. So its best to make sure the problem is really a problem, and really justifies gambling on letting the dealer touch it.
If my tranny makes a dull "thud" noise when shifting into D from R, I would consider that is a problem.
He thinks it's his tranny though some of us believe it's his driveline...cuz they all do it some.
