Trailer Tech extended sway bar links
HI all today is the day. I have one question to start with. I don't have a level driveway. It's not real steep but is definitley on a slant. If the front of the vehicle is pointing uphill should I do the backs first, then turn it around and back it in and then do the fronts. So which ones should I do the uphill or the downhill ones, or does it matter?
It doesn't matter where you start. Not even sure you need to lift your car, so I'd just block the tires for safety, pull the ebrake and go for it.
