I wanted to pull a trailer with my 80 last weekend, but had a problem with the trailer lights. Here is what happened. I have an enclosed trailer, with regular running lights, and also interior lights. When I plugged the 4pin connector the running lights worked fine. I turned on the interior lights to load the trailer at night, and all the lights went dim, then out after about a minute. I checked all connections and ground and couldn't find a problem.
Then I traded vehicles, and hooked up my Sienna van, and all exterior running lights were fine again. I turned on the interior lights, and all trailer lights went out again. The tail lights on the Sienna also went out.
So I figured the problem was the interior lights overloaded the circuit and blew out a fuse. (this is a new trailer for me) I replaced the fuse for the Sienna tail lights and the tail lights, and trailer running lights worked again. I left the interior lights off after this point.
I then changed the 80 fuse for tail lights, and hooked up the 80 again, but this did not solve the problem. I suspected it wouldn't because the tail lights on the 80 never stopped working, and the fuse did not look blown. I looked in the manual for a specific fuse for trailer lights, but could not find one. I then pulled every fuse, both under dash and in engine compartment, but could not find one that looked blown. Granted it was late and I was working with flashlight and streetlights, I may have missed something.
What is the problem here? I ended up pulling the trailer with the Sienna.
