Trail-Safe FJ80 Inner Axle Seals
Tired of dealing with oil leaks from your front inner axle seal? Trail-Gear has remedied that issue by offering our new Trail-Safe™ FJ80 Inner Axle Seal. The Trail Safe™ inner seal lip is totally supported by a garter spring applying constant force over the full 360° circumference. This prevents any deflection gaps and stops oil from bypassing the seal lip. The outer seal lip acts as a secondary seal and keeps debris and other contaminants away from the inner seal lip.
The O.D. of the Trail Safe™ Seal is 100% rubber coated so that it forms a complete static surface seal resulting in zero leaks, and the outer flange prevents the seal from being pushed too far into the axle housing. This is by far the most effective inner axle seal on the market, and will help you keep your favorite trails free of oil.
Application Data:
 1990-1997 Toyota Land Cruiser FJ80
 1995-1997 Lexus LX 450
Trail-Safe FJ80 Inner Axle Seals (Pair), 303751-1- KIT, $16.54
The post Trail-Safe FJ80 Inner Axle Seals appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
  1. Trail-Safe™ Nissan Patrol Inner Axle Seals
  2. Trail-Safe™ Samurai Inner Axle Seals
  3. Trail-Safe™ Toyota Rear Axle Seals
Continue reading...
