stopped by the dealer the other day to see if there was a traction control switch for my 08 fj. After looking at the computer, it showed that there was a slot for tracion control next the diff lock. Top left. parts guy said that if there was wiring for it all you would need to do is buy the switch to be able to turn it off. got the part # and ordered it online and saved about 20.00. what I got was a Auto LSD switch. Plugged it in and nothing happened. Everything was there to make it work, and yet it did not. THe Auto LSD is used on the 2wd fj's is what I found out and the part # is for 2wd and 4wd and the owners manual said 2wd only? I know about the wire on the master cylinder, putting a swithch in, Toyota machanic said that that wire is for the fluid level indicator light. what i am wondering, is there a manual switch that is depressed when you put it into low range? when in low range all that traction stuff goes off. any thoughts?
