Toyota Sequoia 2004 LED Headlight Replacement (High/Low – one bulb)
Fairfax, VA
I looked on ih8mud but did not find any relevant entries for my Toyota Sequoia 2004. So went on a quest to find my own solution. I ended up buying SEALIGHT H4/9003/HB2 LED Headlight Bulbs X1 Series Dual High/Low Beam Xenon White 6000K 6000LM – here is the link - Amazon product ASIN B071R3KTBB. For $37.39. Don’t make the mistake I did and buy a cheap LED that does no match the positioning of the bulbs in the OEM housing. They will fit your Toyota Sequoia 2004, however the beams will likely be all screwed up. When I installed the above, I could not tell the difference between low beams and high beams. That got me to doing more research about how to adjust the beams. Come to learn that not all LEDs are designed to mimic the same position of the bulb in the housing to provide the correct illumination through the stock OEM lens. See video for a full and detailed discussion .​
I called Headlight Revolution and talked with Haley. She was extraordinarily knowledgeable and efficient. I told her my requirements: Plug and Play, easy to install, full utilization of stock lenses, must warm highlight enough to keep snow and ice from freezing up the headlight, low noise fan (not going off-roading to listen to stupid LED light fans), economy without sacrifice. She recommended the H4: MORIMOTO 2STROKE 3.0 $194 - H4: Morimoto 2Stroke 3.0 | Headlight Revolution - https://www.headlightrevolution.com/h4-2stroke-led-bulbs?quantity=1
I also needed to replace the headlight dust covers/housings because mine were a little brittle and wanted to protect the new LEDs – she let me know that I needed the 90MM replacement housings: Rear Headlight Seal Rubber Housing Caps for retrofits | HR - https://www.headlightrevolution.com/rubber-housing-caps-A-HCAP_2?quantity=1 (Qty 1 = a pair (2) housings.
See video about the H4: MORIMOTO 2STROKE 3.0 - Luminosity Reinvented - Morimoto 2Stroke 3.0 LED Bulbs Details and Function - https://www.youtube.com/watch?v=IWDjFQuT7Gs
These guys at Headlight Revolution really know their business!!!!!
I placed the order. Free shipping for orders over $100!
Once installed I will post my progress.
