SOLD Toyota Landcruiser 1997 (FZJ80 Fully Locked & Loaded) ...SOLD... SOLD... SOLD....
Hey there fellas,
I'm new to posting and classifieds section so please bare with me..
This rig is located in Roseville, CA, USA ... I'm hoping I can find a local buyer because I don't want to deal with shipping..
It's currently listed on Craigslist (Sacramento) and there is a link at the bottom..
This FZJ80 Landcruiser is in IMMACULATE condition and has a clean CARFAX....
It's been maintained with MOBILE-1 engine oil every 3k miles and Synthetic oil changing of the Transmission, Transfer Case and Differentials, along with multiple tune-ups along the way... The entire drive-train is still within Toyota specs even with the current mileage....
short break-down of rig below:
* It's a 1997 model which is the last year of the solid front axle
* Full-Time 4 wheel Drive
* Its fully locked... front diff, transfer case & rear diff... with 5.29 gears...
* It is accident free, dent free and rust free and never been off-road yet....
* clean CARFAX and records..
* 37" Pro-Comp MT2's
* 4" lift from SLEE with a ton of upgrades
* 4.5 litre, Inline 6 cylinder with 4 speed overdrive transmission
* front and rear coil spring suspension as opposed to leaf springs
* full floating rear axle
Loooong break-down of rig below ..
The following components were installed by SLEE in CO, Red Sun Auto Repair in Rocklin and Mudrak in Sonoma ...
2 x SOF4FM Front Coil Springs
2 x SOF4RM Rear Coil Springs
4 x Slee Reservoir Shocks by ADS Racing Shocks
1 x SD24 Steering Damper
1 x Slee Front Control Arms with Bushings. Axle Side, urethane, frame side, Toyota OE.
1 x Custom Double Cardan front drive shaft.
1 x Original Toyota rear drive shaft
1 x one additional Custom Double Cardan rear drive shaft as a backup from Southbay Driveline in San Jose, CA ...
1 x Front Sway-bar Drop Kit
1 x Rear Sway-bar Drop it
1 x Rear 2" Bump Stop Drop Blocks
1 x Front 2" Bump Stop Drop Blocks
1 x Set Stainless Steel Extended Brake Lines
1 x Front Panhard Rod
1 x Rear Panhard Rod
1 x Set Adjustable Rear Upper Control Arms
1 x ARB Differential Breather kit
1 x Emergency Brake Cable drop bracket
1 x Drag Link (Part: SOF1321)
1 x Tie Rod Part: SOF1322
1 x Slee Front Bumper (Part: SOF1080)
1 x Slee Knuckle Rebuild Kit (Part: STF1073)
2 x Fully Rebuilt Front & Rear Differentials with 5.29 Nitro Ring and Pinion Gear Sets and Factory Toyota Install kits ...
2 x ARB Air Lockers Front and Rear with an ARB Twin Compressor Kit and an ARB Manifold Kit installed with the original Factory Toyota Switch
1 x Original Toyota CDL switch installed as well...
1 x Slee Transfer Case Belly Plate Part: SOF1127
1 x Warn M8000 with Synthetic Line and Hawse Fairlead
1 x Rigid LED light bar 14" E-Series LED Light Bar Custom Built for the Slee ShortBus Bumper
1 x LED Headlights (high & low beam)
1 x Slee 9005/9006 Head Light Upgrade Harness & Slee Auxiliary Light Harness
1 x High Clearance (HC) Rear Bumper purchased from (BIO)
1 x Tube Sliders purchased from (BIO)
1 x Brand New (Denso) AC Compressor Assembly which includes Fan Clutch and Belts...
5 x SCS F5 Bronze 17x9 wheels
5 x Pro Comp 37x12.50R17 Xtreme MT2 Tires from 4Wheel Parts .....
1 x Hi-Lift Jack 60 Inch X-Treme Jack - XT-605 from 4Wheel Parts ......
4 x Remanufactured OEM Brake Calipers, Factory Toyota Rotors and Pads + shoes for the e-brake just installed one week
ago....
I removed the roof rack, had the holes welded up, blocked over and primer sealed by a local body shop.... I then had the entire Roof sprayed with (white color) LINE-X ....
Way too many parts to list....
This truck has over $3000 in Dynamat and Dynpad installed along with an entirely new interior.....
New Ivory color Vinyl wrapped Headliner and pillars
New Carpet Kit
New Real Rosewood Dash Kit
New Ivory color Leather Seats in the front....
Please Note: the 3rd Row Seats are in Excellent shape and included...
New Windshield glass with OE Toyota weatherstrip installed recently...
New Rear (right & left side) single one piece glass (South American model) installed since the sliding aluminum frames always rust away and cause leaks...
New Limo TINT installed on ALL the windows ($400 job....)
All new Window/Door Trim from my local Toyota Dealer installed including window switches and electric door lock motors and countless other items ....
The only item not installed is a STEREO and ANTENNA ...
Asking price $24,900
Toyota Landcruiser 1997 (FZJ80 with Lockers)
Please feel free to PM or just call me direct....
Call Nick @ 650-5five7-6595....
Good looking 80. Couple of questions...
How many miles are on it?
(Edit: saw miles in CL post...293k)
Why the different steering wheel/airbag delete?
Yea that’s one nice cruiser. @L@ So clean! Glws.
I have both the airbag and original steering but i always liked the MOMO wheels not to mention it cost half the price of re-wrapping the original...
Sounds good, how about performance wise and overall feel onroad/offroad?
