Toyota Gear Packages - Just Differentials
Status
Not open for further replies.
Overlanding.
I don't need to regear, my tires are only a little bigger than stock.
It's a common statement and one we enjoy addressing when the opportunity presents itself. Overland preparation tends to add weight to the base vehicle. Bumpers, winches, skidplates and tire carriers can add a tremendous amount of weight from stock. Add a rooftop tent or rack assembly up high and aerodynamic drag is greatly increased as well further reducing performance both on and off-road.
Beyond increased weight, vehicle manufacturers almost always opt for a borderline gear ratio from the factory to optimize unloaded fuel economy. This means that even running near stock size tires, a heavily loaded, taller than stock and factory undergeared Overland 4x4 is a very poor performing machine both in terms of acceleration and fuel economy. This reduces cross country fuel range, on road responsiveness and off-road control all at the same time.
The solution is regearing. Proper gear ratios put the engine at optimum RPM for performance and fuel economy and give you the opportunity to add traction aiding differentials during gear installation greatly enhancing the capability of your backcountry 4x4 in the field, on the highway and around town.
Just Differentials is the leader with gear packages available for all the common Overlanding platforms. These kits include ring and pinions, full master setup parts and everything your mechanic needs to regear your rig and make it function as it should instead of gasping every time you climb a mild grade.
Call us at 866-349-6801 or check out our package options here.
Not at this point. There is very little demand as taller tires can be run to compensate RPM on these. We do get some requests but not really seeing enough to justify the several hundred minimum sets to tool up. We do offer 4.10 4.56 4.88 5.29
any 3.73 options for the post 1990 70 and 80 series cruisers?
One of our customers sent us some pictures of his very cool 2000 Toyota Tacoma long travel build featuring some great aftermarket parts including Nitro Gears and ARB Air Lockers front and rear.
We keep gears, install kits, lockers, axles and tons of other small parts in stock all the time for many different makes and models. Give us a call at 866 349 6801 or email us at info@justdifferentials.com for a quote today!
Diesel owners rejoice, Nitro now offers a 4.30 ratio for 2000 & newer AAM 11.5" rear axles!
Our brand new 11.8" AAM 4.30 gears are what every diesel owner has been waiting for. These new gears fit both the new AAM 11.8" housing and the 2000-2012 AAM 11.5" housings. Anyone with an older model 11.5" who has been waiting for gears can install this upgrade with ease. Larger diameter ring adds extra strength to your rear differential! Upgrade you GM or Dodge 2500 or 3500 diesel today.
AAM 11.8" Differential Gears
2001-2010, GM 2500 or 3500 - GPDURAMAX-4.30
GMC Sierra & Chevrolet Silverado with Duramax
Use AAM11.8-430-NG gear with MKAAM11.5 Master Kit
2011 & Newer, GM 2500 or 3500 - GPDURAMAX2-4.30
GMC Sierra & Chevrolet Silverado with Duramax Diesel
2003-2013 Dodge 2500 or 3500 - GPRAM-4.30
Dodge Ram with Cummins Diesel
2014 & Newer, Dodge 2500 or 3500 - GPRAM2500-4.30
Use AAM11.8-430-NG gear with MKAAM11.8-B Master Kit
The aftermarket is flooded with cheap low quality noisy and hard to set up gears that don't last when worked hard. At Just Differentials we stock brands that we believe in and hold up to what our customers put them through on the trail, race track or towing a trailer.
JustDifferentials.com for all your gear and axle needs.
Just tried to order for the third time over the past couple of years.
After a half hour of fighting with the web site I gave up and went to someone else. Same as the previous times. I'd like to order from you, but your checkout page just doesn't work.
I'm sorry that you had trouble with it, in the future you can always call or email us at 866 349 6801 or info@justdifferentials.com and we can process your order.
We've been putting this LX470 together in the shop over the last few days. Recently we went through the suspension and axles, and added a Nitro Gear Package. Now we are adding Slee Off-Road bumpers, sliders and a Engo winch. If you are in the PNW and need a quote for some work on your vehicle let us know!
All our Gear Package Kits are available online. You can email us at info@justdifferentials.com or call us at 866 349 6801 for a parts quote.
Building a sweet 9 inch assembly in the shop this week. Nitro Nodular housing, Nitro LSD unit, Nitro 1350 forged yoke and a REM treated 3.50 Nitro Gear Set. REM treating produces an incredibly smooth surface finish for reduced noise, cooler running and longer lasting gears. Ideal for keeping gear noise to a minimum and an option on some Nitro gearsets.
We can build one for you as well, or just about anything else for your axles. Call 866-349-6801 or click on the link below to see all our gear and axle options:
Nitro Gears at JustDifferentials.com
The little guy is a Toyota 8 inch pinion gear. Big one is a Nitro 11.8 AAM pinion gear going into a new Chevy. We stock them both should you be ready to regear everything from a mini truck to a seriously built HD diesel. Give us a call at: 866 349 6801 or email us at: info@justdifferentials.com if you have any questions or can't find what you need at: JustDifferentials.com
A huge shout out to Canguro Racing for a first place finish in the 8000 class at the Vegas to Reno desert race this weekend! Check out the link to a short video below to see just what their suspension, NITRO gears and axles go through during testing.
96 LX450 , factory locked , i just put 17 inch rims with 35 inch tall tires on yesterday they are an inch or 2 taller than my old tires and i am really feeling it from a stop. i dont know what i have stock though . 142k miles front axle has been rebuilt about 8000 miles ago , serviced the rear at the same time . suggestions?
Status
