TOYO KEY OBDII program Toyota G chip H chip all key lost with CN900 MINI
China
TOYO KEY OBDII KEYPRO Bluetooth is a connector which support Toyota G chip, Toyota H chip all key lost write chip and program new key. It can work with CN900 MINI and ND900 MINI via Bluetooth to connect car!
TOYO KEY OBDII KEY PRO main unit:
TOYO KEY OBDIIKEY PRO functions list:
TOYO KEY OBDII plugs in car OBD2 port and connects with CN900 MINI/ ND900 MINI via Bluetooth. You operate on CN900 MINI/ ND900 MINI screen.
TOYO Key support Toyota G chip H chip all key lost:
1. TOYO-G (80bit) all key lost, write chips!
2. TOYO-8A (128bit) all key lost, write chips!
3. TOYO-smart card all key lost, write chips!
4. DAI-G (80BIT) all key lost, write chips!
5. NO need to take out instrument desk! (Avoid damaging the car system)
TOYO Key can program new key on:
Toyota ID72 (G) all key lost
Toyota 8A (H) all key lost
In the coming days, TOYO Key is able to program key on:
Toyota smart card all key lost
VW Audi 48 chip all key lost
How TOYO KEY OBDII with CN900 MINI do Toyota G chip H chip all key lost?
First you should activate and register TOYO KEY OBDII.
Then you can use TOYO KEY OBDII with CN900 MINI.
To activate TOYO KEY OBDII:
Step1. Update CN900 MINI software to newest V1.20.2.15. (If you fail to update at first time, please try until success!)
Step2. Start CN900 MINI device and choose “OBDII Comm.” function;
Choose “ID72 (G) IMMO reset”
Step3. Then it will show you serial number and ask you to input the activation code.
Please take a photo of this screen and send it to eobdtool.co.uk salesman. We engineers will calculate the activation code for you!
After you get the activation code, now you can input the code then activation and registration complete!
(Please note: one activation code can register only one CN900mini device, it cannot be used on other CN900mini devices, please operate according to this guide.)
To use TOYO KEY OBDII:
Set TOYO KEY OBDII program new key as example
Step1. Insert the new key to turn on ignition then plug TOYO OBDII into the car OBD2 port.
Step2. Use the option 72G of CN900 MINI to connect then start to initialize data. The IMMO indictor will be on for a long time then follow the CN900Mini prompt to operate.
Step 3, It will prompt “Complete/ Success”, and then the IMMO indicator will be on for a long time again.
Step 4: Turn on and off ignition for 5 times quickly, IMMO indicator is off.
Done!
Two options recommended:
TOYO KEYOBDII+CN900 MINI
TOYO KEYOBDII+ND900 MINI
Xmas Sale 2017 TOYO KEY OBD II KEY PRO Support Toyota G & H All Key Lost Work with MINI CN900 & MINI ND900-go
