1998.5 dodge 3500
Custom 18 in lift
Pro comp Es300 Coilovers (front)
3 Rancho 5000 steering stabilizers
All laser lined
Reversed cut dana 60 (front) has been cut & rolled for correct pinon angles
Dana 80 (rear)
Auburn possi carrier
35 spline axles ( front& rear)
Custom 500HP cummins 84k miles
Marine head & injectors
Marine pistons
Banks evo turbo
5" down pipe with dual 6" exhaust
Cummins pcm
Stacked tst on board fuel and boost management system
New heavy duty NV4500 from Farnsworth trans in Amarillo, Tx.( warranty)
True speed for accurate odometer reading
Bds exhaust brake
22.5 Alcoa wheels, 385x75 radials ( 43 in tall)80-90% tread remaining
Goose neck hitch & trailer hitch
Retractable Steps (Come down when door is opened)
Sony Cd player/ready for subs
Etc.
Etc.
The list is endless, there is over $70k in the truck, 84K ORIGINAL miles (Not rebuilt) Its been used to tow, easily gets 20-30 MPG While towing a trailer and four ATV's on the highway. This truck is really fast, once you pop it in 3rd your gone 4th and 5th are even better. It can easily cruise at 90mph.
There are some scratches, in the bed and on the body but as you can see by the pics there not noticeable. The interior is perfect no scratches no burns. There is a crack in the windshield but its not in the view of the driver or passenger. I had a rear window installed after i took the pics, so i does have a rear window.
Asking 20,000 Its on ebay for 16,900 with no reserve.
Located in Boulder Co i will deliver within 500 miles
Custom 18 in lift
All laser lined
Dana 80 (rear)
Marine pistons
Banks evo turbo
Cummins pcm
Bds exhaust brake
Etc.
Etc.
