Torque wrench and crank pulley holder to borrow.
Monument COLORADO
Does anyone have the goods needed to torque the 1fz crankbolt to 304ft lbs before I go making something to hold the pulley and buying a torque wrench? Thanks in advance
Pete
You can rent the torque wrench at AutoZone I think.
I have a 3/4 torque wrench to 300. A socket on the flex plate bolt, wedged against the trans housing will keep it from turning. That's what I have done 3 time with no issues.
I don't think they had one that goes up that high the last time I checked but it is probably worth double checking with them. If not I may just pick up a torgue adapter that has that range and use my 3/4 drive ratchet with a cheater on it. And I can whip up plate to hold the pulley pretty easy at work. Thanks
I’ve got the same and done the same without a problem. @Pz10420 if you haven’t done it yet let me know. I’m sure either of us can help you out.
