Toronto area shop that can install static suspension in LX470
Can anyone recommend a shop in the Toronto area to replace the AHC suspension with a LC static setup for a 2006 LX470?
Reach out to Justin in Markham. +16476768826
He has a shop and had ahc removed on his own lc100.
Is yours shot?
Mines still works with minor issues. Same as yours 2006 lx
Have you ever found anyone with techstram software to check the pressures?
Filipe
Ontario Cruisers
Is yours shot?
Filipe
Ontario Cruisers
Thanks for getting back to me. Do you know the name of Justin's shop?
No I haven't tried to measure the pressure in the system. Right now, I'm pretty sure mine is at 0.
The suspension was working just fine but sprung a leak in one of the lines. I tried to replace the line but rust has taken over. The bleed screw crumbled when I tried to open it. Tried to remove the whole actuator unit (with globe) and the bolts holding the assembly to the frame also crumbled. Would take a grinder to cut the four actuators off to replace all the bleed screws, assuming that can even be done. Worried that I might just be opening up a can of worms. Neil was right, rust never sleeps.
Yeah, with rust all over, it's much difficult to fix it.
Do you know anyone that could check the pressures?
His shop:
20 heritage rd. Unit 14 k-star auto
Is yours shot?
Filipe
Ontario Cruisers
If you need help in the future, maybe register on our Facebook group, Ontario Cruisers.
We have been sharing mechanics and shops locations, trails, gear for sale, etc..
