Haha thank yall!! Yes, I live at home now, but am transferring in the fall (War Eagle!). And as far as workspace, my grandfather's hobby is to work on raceboats, so we have every tool imaginable and a covered work space (which is needed in the Florida weather...). I figured I could do the smaller things my self. Shocks shouldn't be a problem (helped a buddy install some on his Dodge last month, wasn't bad for the two of us). Already did the t bars, diff drop and spacers is a good idea... Timing belt and water pump I was quoted at $900, which if parts are $600, is worth chucking out the cash to avoid opening that can of worms... My main concern was putting all this money/time into my truck only to have something else die on me soon after. I just don't want it to be a constant expensive and extensive project.
Once again, thank yall very much for basically confirming that I'm doing the right thing!
Haha, im in a similar situation but mine has been on the East Coast its whole life so most stuff that can go wrong due to deterioration is sped up over here. Some future things to look out for is brake calipers. hopefully its the rear ones first for you those aren't terribly expensive to replace and your probably going to want to replace 02 sensors (also not to expensive) as for that water pump dont risk it your going to want to replace that asap. Maybe one last thing to check for is your suspension bushings. Nothing to bad has gone yet and like most are saying its probably cheaper to stick with your hundy for now and once you graduate is when you can worry about a new car.
