tires on a tj not centered
Conway, SC
Website
www.lowcountrylandcruisers.com
My friend just bought a 2000 TJ with a 2 inch coil spacer lift and the tires are sticking out further on one side than the other. As far as we can tell it hasn't been wrecked via carfax and visual inspection. My brother tried to center the axle with track bar relocation brackets but it only seemed to make it worse. Do you think we need to try an adjustable track bar or what? It is only 2 in spacers and we are stumped. Any recommendations would be greatly appreciated!
Adjustable track bar will definitely let you center the axle. You will probably need to adjust the drag link to center the steering wheel when you get the axle adjusted. CM
