The TPM light has come on, great. Air pressure is good on all tires including the spare. When I try to reset I only get one flash from the TPM light instead of three (per the owners manual) and it will not reset. In searching it appears that each of the valve stem TPM's could have a battery on them - and that one or more has probably failed. Can you replace the battery (and how do you access them) or do you have to replace the entire TPM/valve stem assembly? Can I pull the fuse and try to reset the computer? The TPS computer was replaced under warranty shortly after we purchased the 100 in 2007 for a similar issue. Unfortunately I don't have the FSM for the truck (the only one I've never had a manual for).
Truck is a 07 100 with around 75k miles. (Wife's DD)
