I just pulled my center console apart to clean the PO's 7 years coffee and I decided to check out the "sub" in the arm rest. Well it's a lot smaller than I had imagined. I think it's a 3 1/2" speaker
I don't know too much about speakers but this one is not great, although the magnet is large for a speaker that size. The thing I noticed is that it's 2 ohms. I thought most car speakers are 4 ohm. I know that if I replace it I should use the same resistance speaker or higher. If I go higher, say 4 ohm, will the power I'm sending it be reduced? Will the volume be lower at the same power output from the deck?
Have any of you guys replaced the speaker for something bigger, better? The bass box is very small and sealed. It doesn't look like anything bigger will fit. Although I could port it.
