Time for Valve Cover Gaskets, anything else at the same time?
Here’s a list of part numbers:
Valve cover gaskets:
11214-50011 for driver side
11213-50031 for passenger side
New valve cover bolts with washers, 9 per side: 90080-10330
Spark plug gaskets: 11193-16010 (left) 11193-70010(right)
Oil filler with gasket: 12196-50010
PCV valve: 12204-50020
Grommet: 90480-18001
Ventilation hose: 12261-50050
Foam covers 12235-50010 and 12235-50010
FIPG: 00295-00103
Spark plugs:
Denso 4702 IK20TT Iridium TT Spark Plug
SKU: #IK20TT
This was very helpful. For the:
Spark Plug gaskets, I need 8 of these - correct?
Ventilation Hose: how many of these should I order to have on hand?
Foam covers x 2?
Thank you, this forum is incredible.
Foam covers x 2?
4 right 4 left spark plug tube gaskets
that vent hose and part number above is only for the PCV foam covered hose
foam covers above are two diffrent shapes, one for the PCV valve body and one for the other end
Thank you, are there 2 different part numbers then? list has:
Does anyone know if the valve cover from a 2003+ would work on a 2001? The valve cover gaskets are the same and I don't see Toyota making a significant enough change to the head to warrant a new completely different valve cover.
98-02: 11202-50040
03-06: 11202-50041
For those wondering why, I like that the 2003+ uses the threaded PCV valve instead of the stupid grommet thing.
