Time for a new drive shaft....
Howdy! If only the tube is damaged, any good DS shop should be able to supply whatever thickness you want. So why do you like to replace driveshafts so often? John
Avoid large rocks, Bigger tubes means something else has to give.I mean this in a humerous way I know its hard to resist and harder to avoid them.I just took mine to a shop here the 120 tube is 8 dollars an inch.I ll be looking at the better part of 400 bucks after its done. The long one is the one I,m haveing done with a cardan joint.For this price I suplied the parts for the joint and put it together with the weld on flang. Not cheap.
Thanks D,Animal already changed that and had it on my rig I just welded it myself and it turned out REALLY bad.and was a partial cause of my death wobble while engaged.So Im getting it 1/2 in longer ,thicker and balanced,as our canadian winters sometime require 4 wheel all thetime.
