So here's the symptoms I've been having. Slight shimmy at 70 mph. Significant inner tire wear. Shimmy under braking like warped rotors. So I jacked up the front end and the passenger side seems like it has no play. All the joints feel tight. Drivers side feels like a tie rod is loose. Outer tie rod is tight. Feels most like inner tie rod, but it's hard to say. I didn't cut the boot off.
So my questions are these; If one side feels tight and the other feels loose, is it possible that it's the rack? Is the interior shaft of the rack a solid piece. If so it must be the inner tie rod. Of course I'll have to cut the crimped strap on the boot to get a good look at it, but if it's a solid shaft it's probably got to be the inner tie rod.
Second, I've never had an IFS with a rack like this before. Does, or could, a single loose joint cause the shimmy? If so would it make sense that it would cause a condition similar to warped rotors? I spun the front rotors and they appear under my non-scientific visual look compared to the calipers that they are true.
Thanks,
jetboy
Thanks,
jetboy
