Tie Rod Ends.....are boots available?
Kofoed
I tore one of the boots (with help from some brush). Rather tahn replace the whole end (and maybe requiring an alignment) does somebody know of a p/n or kit?
Critical parts, I would use genuine OEM. That being said, these are just dust boots and really easy to replace. I found myself in a similar situation last year and ended up with these.
~12usd at O'Reilly AP.
https://www.oreillyauto.com/detail/...4500287/2001/toyota/land-cruiser?q=boot&pos=6
The fit of the boot is perfect. Only downside it that it came with zip ties to replace the inner retaining clamp. If your careful and patient you'll be able to remove and re-use your factory inner clamps. Your factory outer clamps can be re-used no problem.
Oophs, I should have clarified I am looking for the outers ends that connect to the steering knuckle
So then, you've torn an outer CV joint boot...., you have a greasy mess now, correct?
No. The picture of the bellows you posted was for the inner rod end....I am looking for the outer. Steering linkage, not driveline
I rebooted my LX470 tie rod end with Trail Gear Tie Rod End Replacement Boots - 130089-1-KIT. I didn't use the small ring that came with the kit because it is too small for the 100 series.
tie-rod-end-reboot-jpg.1694533
