Wanted Throttle Linkage Parts for ‘74 FJ40
TN
  1. 40 Series
Tennessee United States
I’m needing to find the vertical rod that connects the pedal to the horizontal rod up the firewall (78103 or the older version above). I know there are different lengths of these throttle linkage rods and I’m needing one that is about 7”. I circled the two examples of the rod for reference.
Also needing a throttle return spring if anyone has a good source.
Thanks
Thanks
i do have each of your 3 stand alone parts topics :
both Rods are NOS oem parts
the return spring is my very Cat's Meow Meow grade reproduction , with
37.4% more spring tension then the original one
i will need tech pics of your oem stock gas pedal arm in the resting position sticking out the fire wall here as well
- YES , this works wonders on F1.5 's too 20R 22R also
PM sent
thanks
matt
