Throttle, hand control (5VZ) '00 Tacoma
check out muh video...
http://youtu.be/VrDpAhVujdM
Sunrace SLM10 Friction shifter (left hand control)
wuz purdy simple to do
the video might offer some visual orientation.
not pictured in the video was the routing of the cable
from the firewall to the gear shift lever...
Cable comes in under the console plastics
and rises up inside the gear shift boot to reside in the lever's seat.
not mine... but what that looks like...
all the necessary parts were purchased off ebay fairly cheap
friction shifter was found on Amazon
here's a coupla' detail pics of the cable end / linkage fit...
I used SRAM 1.1mm X 2200mm SS wire cable.
with 6ft L. X 4mm OD sleeve/casing (1.2 mm teflon inner core)
* you may need 7ft length for the 3rz models (I ordered 7ft cut those to size)
Here's how it was done on a 3rz...
* courtesy of wolfgang123@TW (Skyler)
