Alright, so i've got an 89' 4Runner 3.0 with about 273,000 on the clock, been in the family since new and have had pretty much zero problems with it...
two days ago, amoungst the sub-zero Colorado temperatures and snowstorms it suddenly felt like it lost power. the engine shakes the bejesus out of the truck whenever you give it gas, and at idle the exhaust has gone from a pur to more like a motorcycle...
no ECU codes or light, sounds like a dead or consistently misfiring cylinder.. threw in a new set of OEM plugs just to rule that out with no change (when i did a full tuneup in 2006 i used everything OEM except for the plugs
, figured i would do them anyway)
sprayed carb cleaner all over everything... couldnt find any vaccum leaks.. did a half dozen or so other checks, then got lazy in the cold and decided to run it to my shop to diagnose it for me...
so i go and fire it up after screwing with it all day to run it to the shop, and its magically running perfectly fine!...yay! crisis averted!
So i drove it around all day yesterday with no problems, and all day today, then as i finish up my last stop (had to get my pankcake fix) the problem is suddenly back!
So what gives? still no check engine codes either.. i was going to do a compression test but the problem went away before i did, and even so, bad compression would be a constant problem wouldnt it? not a 100% on or off type thing? perhaps a fuel injector that is in its death throes?
No smoke or any signs of a blown head gasket, been poking around the wiring to see if theres any loose connectors.. what would cause it to go away and come back again a day later? thanks in advance!
