Three belts. How do the numbers translate and can you help? (1 Viewer)
glendale, az
Replacing the belts on the 3F in the ‘85 fj75 troopy. I could use some help with belt numbers and what to buy in todays market.
belt # 1
(i think) the number is : 90916-82137-83.
Belt #2
90916-02141
Bel #3
A-45 PANDA
im assuming the numbers have changed As time goes on.
thank you for your knowledge sharing.
You can use the parts diagrams on the jp carparts website to find the original Toyota part numbers.
Just make sure you pick the correct belts for the 3F.
Alternatively, you can put your chassis code into toyodiy.com and get the part number also.
All should be order-able from your local dealer.
Dealer is a no go. Larry Miller Toyota is not helpful at all.
The part numbers you need:
90916-02141-77
90916-02193-77
99332-11180-83
All three are available from any Toyota dealer in the US.
Thank you. Thank you.
