For Sale Thousand Oak, CA - Xantrex XC Pro 2000 Inverter/Charger + Freedom X remote panel
So Cal
  1. Other
Thousand Oaks, California United States
Virtually brand new. I this unit received w/ 2 Dragonfly 100ah lithium batteries from my brother's rv. He was upgrading to XC Pro 3000. All in perfect working condition, and reduced price. Comes in box (XC pro3000 box) with all manuals. Perferred local pick up. Will ship for actual cost at buyer's expense, or provide your own shipping labels.
Xantrex XC Pro 2000 Inverter/Charger + Freedom X remote panel $700
The Freedom XC inverter/charger offers premium performance in a lightweight compact package. It cranks out full output in invert or charge mode from -4°F - 104°F for operation in all climate temperatures. The extended surge rating of the Freedom XC makes it ideal to start difficult loads including fridge and microwave. The quick connect terminals at AC IN/OUT make installation a breeze.
INVERTER FEATURES​
  • Extended Surge Rating - Surges to 2X continuous power for 2 seconds for motor loads
  • True Sine Wave AC Power - For operation of sensitive and motor loads
  • Ignition Control - Feature to turn inverter on/off via a 12 VDC signal and to minimize battery drain by switching the inverter off when the ignition key is turned off
  • Wide 10-18 VDC Input Range - Ensures inverter operation on high voltage alternators found on many new vehicle chassis
  • Programmable AC Under-Voltage (85-110VAC) Shutdown - Feature ideal to operate under weak shore power or generator input
  • Built in 30A AC Transfer Relay - Senses when outside AC Power is present and transfers the load from the inverter to the source of incoming power
  • BUILT-IN CHARGER FEATURES​
    • Power Factor Corrected Multi-Stage - Utilizes less shorepower when charging batteries. This frees up more usable AC power for running electrical devices and appliances and reduces the likelihood of tripping shorepower breakers
    • Programmable - Configurable 3 stage temperature compensated battery charge algorithm for optimal charging of almost any battery type up to 18V
    • Battery Equalization - Maximizes flooded battery life
    • Dead Battery Charging Down to 0 Vdc Power Share - Prioritizes AC loads by reducing the charge current and maintaining the total input current to less than the breaker setting
    • Lithium-Ion/Battery Support - BMS Required
FREEDOM X Remote Panel
  • Digital remote panel compatible with FREEDOM X and XC models from Xantrex
  • Control and monitor the inverter from a convenient location
  • Monitor AC in/out voltage/current, battery voltage/current, percentage status bar for inverter AC output, and fault and error codes
  • During battery mode, the user can see the current status, change functions, and view information from the digital display
