My tstat is possibly shot. My temp gauge reads Cold all the time. Is it ok to drive this vehicle for 3 hours highway today? Does the engine always stay cold and it's ok or am I going to blow my head like an idiot if I drive it like this?
I'm going to guess that it's the sender unit.
Randy-Weird parallel universe here, but I have the same parts coming from Dan. Thermostat, gasket, oring, temp sensor and new housing bolts. Find me at Surf and Turf and show it off, since I won't get to it before the trip. I'll be in the faded blue FJ60 near the trailers in the main camp.
I will be in a grey FJ62 with an ARB front and a Kaymar rear. I might put the con-ferr roof rack on for show.
What are these "new housing bolts" you speak of?
For what ever reason, the housing bolts in Toyota thermostat housings are extremely brittle and tend to break rather than unscrew. I just always install new ones when I do a thermostat. I think they are $0.70 each, so not a huge expense. I forgot to mention, I'm also replacing those 2 small curved hoses over top of the housing that take coolant from the throttle body.
You did not solve the actual problem . Why was it overheating initially?I replaced all those on my 60 recently. The truck was without thermostat when I purchased it, Started to overheat, went and have the radiator cleaned at a radiator shop, still was overheating. went an put in a thermostat and then started overheating pretty bad. I have a second Temp gauge and it was showing 240 degrees. So, I removed the thermostat, re-cleaned the radiator (dumped some orange based degreaser), and problem solved. Sorry that you guys that live in the north need to have a thermostat here in P.R. heaters are extra weight in the vehicle and thermostats are for vehicles with computers.
PS. I cracked the housing, top and bottom but JB Weld rescued me.![]()
