Build The Warthog - 1977/73 combo
it requires diligence of ownership...
So I’m ready for some road miles starting tomorrow. I’m local through Wednesday and the weather is great so I’m off.
In the mean time the only off thing so far is a quirky electrical system.
I pulled the fuse box and cleaned and cleaned again. Added some terminal grease and got every fuse junction working but one mis-placement of a fuse and that section goes out. Box looks great. Fuses are tight. Frustrating.
Then I look at @Racer65 page and I’ll be damned if this 77 FJ40 box is not the same as my Pig.
I should have known. I’d have tossed this $70 part at it long ago.
Fuse Box and Cover for '72 to '77 Land Cruiser FJ40
Stopping is good Bob.....except that time the engine died.....
The only main issue I have felt since I fired up the Pig a year ago was a pretty wicked “shudder” when I released the clutch in first and reverse.
I have been thinking it was a bad clutch but after driving it hard all day I realized the clutch is great in all the other gears so it had to be something else.
That will do it every time........
Big improvement for sure.
Talk about an "Ah-ha" moment! I do have some nasty shudder when starting out in 1st. I always ASS-umed that I should have had the flywheel re-surfaced when we did the swap!
Which mount is that?
Thanks for posting this detail, it could make a big difference for me!
Drivers side. May help. Mine still has some I know is the flywheel but I’ll deal with that for a long long time before a tackle a clutch. I did 3 clutch jobs in 2017 and that is 3 too many.
Oh and the new name is the Warthog
The Warthog got 100 miles today.
Hauling that ass.
Showing my latest tractor for the farm to my accountant today
My wife shaking her head when I pulled up at the gym
DS front mount, yes?
You still have some chatter?
Chatter yes. Entire drivetrain shudder went down 75%
Put a bottle jack under the block above the driver axle pad and lift. If the motor mount is toast you will know quickly.
Turd polishing continues
It’s remarkable what CLR and a Scotchbrite will do
This door is 1/2 done above
Side by side
Finished these two doors.
