The Ultimate A/C Thread For Pigs! (Air Conditioning)
It looks like @cruisermatt sells some adapter fittings for an LS (Delco?) style compressor that look similar to what you need. Maybe someone out there is making something similar for the 3F?
@J Mack ?
Good call!
Matt is going to get back to me when he catches up…
Coming along nicely. Just an observation, you might want to shim your clutch plate before you get the compressor permanently mounted up. In your pictures it appears to have no air gap even though it’s not engaged.
Thank you, I am going to have to go back to this…
The clutch is new from Cool Stream, so I would hope it is good to go, but stranger things have happened…
From the photo it looks like you could use two straight sections of hose and a hard 90. I do appreciate that photos can be deceiving.
I need to map out where I want my lines to run.
And then find an ideal source for angled fittings. You can get all kinds of angles. I need to settle on the actual line material and mock up my layout, and make some new PS lines to clear.
What is the best way to check for leaks?
I pulled it down and it didn't hold vac for very long. So I shot a bit of freon and got out the sniffer. It went off inside the cab.
I need to get the proper fittings so I can bench test the Evap properly.
LOL, I bought some dye and pushed it through with a small compressor. Still haven't found any leak. I'm just a one man with too many projects and hobbies. I had to put AC on the back burner.
Darn, and now this link is dead.
If you all wanted to drop the 3FE Denso AC compressor in, but I need some fittings to connect new lines to the compressor manifold - where would you start looking?
The page is gone but the site still exists.
The link description you posted says -
“The adapters are standard #8 discharge and #10 suction fittings…”
Just need to know what the fitting needs are to hook up to the compressor and what size hose you are using then search that combo.
I found the new page - #8 and #10: Denso 10S17F 10S20F 10SE18F Suction and Discharge Compressor Adapters for Sealing Washer Compressor - https://coldhose.com/products/denso-10s17f-10s20f-suction-and-discharge-compressor-adapters-for-sealing-washer-compressor?variant=35532158632096 - just go to Fittings > Compressor Adapters
The Denso fittings look close..
These look like the same fittings - for 10S17F and 10S20F - for a much lower price.
I talked to Cool Stream, the 10P15C takes the 8 & 10 as well.
These are the best prices I’ve seen!
Cool Stream said they have all different types of angles for these fittings, so I am going to map out what I need and see if they have the angles I want for a decent price.
I think I can get #8 and #10 barrier hose locally and get my fittings crimped on.
Just gave them a call yesterday. Sounds like they have adapters to convert all of my old 45* AN males to the o-ring versions. Then ordered one of the Kits that JMack mentioned. Hot weather is a motivator on this stuff. HA
Getting closer! Any suggestions, or specs on how much oil to add to the system?
When I do, just add it to the compressor?
Edit: Found it
After reading this my brain is exploding. 1972 FJ55 AC system all factory. I had a buddy help and we bought some adapters to try a vacuum test. I am also trying to figure out how to pressurize the system so maybe I can just spray soap on everything and check for leaks. If you guys know me you understand this is a bit out of my league. Guess your never to old to learn something new LOL
Start w/ the vacuum test. Pull a vacuum on the system (IDK how much) and then go have lunch and come back and see how you're doing.
I would start w/ that.
I would just take it to someone. Auto AC work, if it only needs charging and/or minor repairs is not that expensive. Of course I don't live in California. They can add dye when they charge it and see the leaks if there are any.
You Tube is a great teacher , I did mine , first time 4 me
Thank for the intro! ^^^
This is exactly what I have, All but the coil, I am running an HEI dizzy. I have read that you use the tach signal wire if you don't have a neg side of the coil available. Grounding the (B) wire doesn't get AC to work in "AUTO".
I moved this system from the 79 parts truck. The clutch will pull in when I turn on the AC, or when I turn on the blower with AC already on. But, only for a split second. Then drops out. I do still see bubbles in the sight glass, so I will try and add more Freon to it. I have been able to this by jumping the compressor to 12v.
I decided to just remove everything and start fresh. Being the purest I am LOL I took my time and removed everything. I was really impressed with this Dealer installed AC unit. I want to be comfortable and upgrading to a completely new AC system offered by Summit Racing for me is the way to go. From the compressor to the wiring harness at some point I will be posting this for sale.
