- Location
- United States
“The Raisin” Toyota Rock Buggy – Off Road Tube Car
$18,500 OBO Located in Golden, CO
It's time to sell The Raisin to fund an Ultra4 car.
This has been a great buggy built for any off road fun. The interior has lots of room for a full day on the trail ( I’m 6.3 and it’s very comfy ). Has a large aluminum storage box for tools, spares and lunch! Also an aluminum bed / platform for more storage or an ARB / Engel fridge. With all this it is also Very capable. It has lots of ground clearance for crawling yet it’s extremely stable.
Toyota Rock Buggy – Some Toyota frame, mostly 1.5” DOM Tube – 109” Wheel Base
Toyota Tundra V8
Tundra 4 Speed Auto Trans W/ High Stall Converter
Marlin Crawler Dual Transfer Cases – Upgraded 23 Spline inputs - 30 spline front and Rear Outputs – HD 30 spline Flanges – Twin Stick Shifters
Diamond Axle Front Housing – Toyota 9.5” Center W/ARB Locker – Chromoly Inner Shaft – 80 Series 300m/Chromoly Outers /Birfields – 80 Series 4 Piston Brakes – Slee Off Road Double Shear Steering Arms
Diamond Axle Rear Housing – Toyota 9.5” Center W/35 Spline Spool – Yukon 35 Spline Chromoly Shafts – 80 Series Drilled and Slotted Rotors and Calipers
PSC Full Hydro Steering - 8” Double Ended Steering Ram - CB Pump/ Filtered Reservoir / Orbital Valve and Catch Can
Slee Off Road 2.5” Remote Reservoir Shocks and Alcan Springs Front and Rear – Rear Traction Bar
Pitbull Rocker 44” Tires on FST Forged Aluminum Bead Lock Wheels
Warn 9.5TI Winch W/ Masterpull Synthetic Rope
PRP Suspension Seats W/5 Point Harnesses – PRP Custom Window Nets Included
Autometer Electric Gauges – Water Temp, Oil Pressure, Voltage, Fuel Level
Cutting Brakes – Individual Left and Right
Spares – Complete Front Diff W/welded carrier - 2 Inner Front Cromoly Axle Shafts (new) – 2 Bobby Long Cromoly outers /Birfields – Complete Double Cardan Front Driveshaft .120 Wall with Long Slip - Complete Rear .120 Wall Driveshaft – 1 44” Pitbull Tire New (never Mounted) - Extra Drive Flange - 2UZ Coil Pack - Extra 9.5 Gear Set
If your serious you can call me @ 303-278-8287 or email Ben@sleeoffroad.com
Thanks
Ben
Toyota Tundra V8
Thanks
Ben
