ARCHIVE The Enduro Joint from Barnes 4wd
Barnes 4wd - Enduro Joint
We recently switched from using a spanner nut system to a new more durable snap ring system!
When Barnes 4WD designed the Enduro Joint we combined the best materials, the best manufacturing processes and the best steel and polyurethane treatments available all in one joint.
The body of the Enduro Joint is Forged 4140 heat treated Chromoly steel. We did not try to cut any corners by making a short threaded shank like a heim joint instead we give you 3.25” of 1.25-12 threaded shank.
That is over one inch longer than 1.25” heims on the market. The Enduro Joint’s ball is made from 52100 bearing steel and incorporates the high misalignment spacers all into one piece of steel that provide 40 degrees of misalignment. Forty degrees of misalignment will net almost 33” of travel on a four foot control arm.
The spherical bearing is then Hard Chrome plated to provide an ultra smooth surface and has proven to provide excellent corrosion protection. The mounting width of the Enduro Joint is 2 5/8” and has a 5/8th or 9/16ths inch bolt hole.
The cups that the spherical bearing rides on are an 88 durometer polyurethane that ensures maximum life, no squeaks like heim joints and they help to dampen axle vibrations felt through the chassis.
The body of the joint is gold zinc plated to ensure that the Enduro Joint looks great for the life of the joint. Once the joint is fully assembled we are still not finished making the ultimate joint. Every completed Enduro Joint assembly is then Cryogenically Treated to give the Enduro Joint the most strength and greatest wear characteristics possible.
They can be found in both LEFT and RIGHT threads with both 5/8th and 9/16th inch bolt holes here:
Barnes 4wd Enduro Joint
These joints are a great value, and always in stock. Let us know if you have any questions or need help finding the correct brackets to use with the Enduro Joint. Remember they come in both left and right hand threads!
Barnes 4WD Enduro Joints being used in a triangulated 4 link suspension by one of our customers:
Check out more pictures of the joints in use, and share your own photos on our Facebook page. You can purchase Enduro Joints on our website and find more information about them here.
