Decided to fix the broken hubs rather than go and buy new AVM hubs for the other Safari. These hubs are auto hubs but can also be manually engaged. I'll likely mod the hubs by taking out a small spring to make them manual hubs. Got a local machinist making up two spacer rings and some metal tabs - see pics below. On one hub the spacer is completely broken and the other has a crack. The metal tabs are also either broken or on their way out. The tabs are what locks or unlocks the hubs manually. The machinist tells me that they are spring steel and he can't cut spring steel - so I will have to harden them after he's done making them. My question is how many times should I heat them to cherry red and dip them in oil to get them about as hard as spring steel? I don't want them too hard or they will just shatter.
Broken spacer on hub clutch:
Cracked spacer with broken tabs:
Tabs inside hub housing:
