Temperature data from a stock ’04 LC with 114,000 miles. I’m chasing a new odor of too-hot oil that’s worrisome and ended up getting some baseline on several components. Ambient air temp was 50. I took all these within 10 minutes of shutdown after a 165 mile trip, with this pattern:
75 miles at 70mph
Short fuel stop
90 miles at 70 mph
7 miles at about 40 mph
Temperature measured parked in my garage, all within 10 minutes of shutdown
From front to back, all temps in F and taken with a new infrared thermometer.
Radiator 184
Battery 92
Fan clutch 144
Serpentine belt tensioner 144
Engine oil filter 166
Power steering pump 132
Power steering reservoir 121
Outer CV, both sides 86
Front differential 122
Front U-joint, front driveshaft 94
Transmission 132
Transmission oil pan 113
Rear U-joint, front driveshaft 124
Transfer case 147
Front U-joint, rear driveshaft 151
Muffler 168
Rear U-joint, rear driveshaft 97
Rear differential 118
Rear wheel bearing, both sides 84
I’m going to keep checking temps and looking for leaks. T-case seems a bit hot and the new odor is of gear oil or grease. The hottest driveline component is a U-joint, so that will get some attention too.
75 miles at 70mph
Short fuel stop
90 miles at 70 mph
Radiator 184
Battery 92
Fan clutch 144
Transmission 132
Transfer case 147
Muffler 168
