Tech Talk: Converting from the electric/power hub to manual AISIN hubs
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
cruiseroutfitters.com
This has become quite a popular conversion in the recent years with the influx of JDM models making their way to the United States. While the novelty of the electric hubs is fun while they work, many choose to proactively swap to manual or wait and swap to manual when they have an E-hub fail. For those wanting to keep the Ehubs functioning, we do offer slip rings and seals gaskets for them. However the electric motors and related components are no longer available and I’m yet to see an aftermarket source.
First off, what is an E-hub?
Parts needed (click link to order on CruiserTeq. com)
Spindles: 2 x FA60060 (Japanese) or 2 x TG140205-1-KIT (Chromoly)
Wheel Hubs: 2 x HUB140436
Wheel Studs (lug nuts optional): 12 x WHL02053 or WHL02053OEM
Hub Stud Kits: 12 x HUB6997K or HUB6997KA
Hub Dowels: 4 x HUB07057
Spindle Nut Kits: 2 x FA60011K
Birf Snap Rings: 2 x FACL31007
Hub Gaskets: 2 x HG60020 (if using HUBFHT007/HUBFHT008/HUBFHT013) or HUGFLG60010 (if using HUBFHT002)
AISIN Hubs (multiple color/style options): 2 x HUBFHT007 (Orange) or 2 x HUBFHT008 (Red) or 2 x HUBFHT013 (Gold) or HUBAISINHD (Heavy Duty)
*Knuckle Rebuild Kit (FA7X99) or Spindle & Backing Plate Gaskets Recommended
NEED HELP WITH PARTS? CALL/EMAIL AND OUR PARTS SPECIALISTS CAN QUICKLY ASSIST WITH THIS CONVERSION
801-563-1277 / info@cruiseroutfitters.com
This will require you to disassemble the wheel hub assembly and swap the spindles. The E-Hub knuckle has a machined groove where the connector leads pass. This will need to be plugged, welded or otherwise blocked off to prevent grease contamination. To be continued...
