- Thread starter
- #21
Jerry, I couldn't imagine this being the case but if you are creating alot of heat near the master cylinder or even the brake lines, the fluid tends to expand and thus increasing the pressure on the caliper pistons. Another scenerio could be that the lines are slightly kinked and as you press the pedal you are forcing fluid through however as you release the pedal it isn't drawing as much fluid back through thus keeping the piston from fully releasing.
What if there were a problem with the brake booster, not having enough vacuum to pull fluid back, is that possible?
I'll be going through the rest of the hard lines to make sure they aren't the issue. When I bleed them, they push out fine but I can't tell if its "sucking" back up when the pedal is released.
Oh well, I knew I shouldn't have bragged that all was good...
