There seems to be a lot of concern about spilt rims and their safety. As far is I have been able to discern, the Toyota style "split rim" is really more of a "locking rim" rather than an old-school two piece wheel.
There are many variants I will try to post some pics when I can get home to my computer but they range from old-style semi wheels to tractor tires, to military and civilian trucks.
https://lh6.googleusercontent.com/-6qoCRxl-o3g/TlUlmmMCjuI/AAAAAAAAcJg/31PEm3VDzWs/IMG_7238.JPG
http://www.stovebolt.com/techtips/wheels/images/splitrim2.JPG
TheToyota wheels work in a slightly different way.
There is a ring that locks into the wheel. The wheel is all one piece. When removed, the locking ring allows the tire/tube combo to be lifted off of the wheel.
The danger is that if the locking ring isn't seated properly the growing pressure in the tire/tube will force the ring off at high velocity. Supposedly taking your face with it
On many types of split rims I suspect a proper seat is harder to spot but with the lock-ring type, it seems pretty clear when it ain't right. I still stay pretty clear of the tire when inflating it. But it seems safe enough.
I do spend a lot of time exploring the back country and aside from the novelty, I do think its helpful to be able to break the bead and re-set the bead without a high pressure burst of air (aqua-net notwithstanding). Also, should the tire need to come off the rim for repair, it's much simpler. Tubes and patches are pretty easy to store
I'm new to this set up too but I'm getting used to it and working out the +\- of it.
