Nitro Gear & Axle
Toyota Tacoma F9 9"
Nitro 3rd Member & Currie Axle Housing Upgrade
This Currie F9 fabricated 9" rear end assembly for the 2005 and up Toyota Tacoma features the complete housing with the Hi-Form 50 steel housing center. It also features 3"x.250" wall d.o.m. steel tubes and custom housing ends that accept the stock Tacoma axle bearings. The housing allows for all factory drum brake hardware and ABS and ESP sensors to bolt back on, as well as new heavy duty leaf spring pads mounted. Also included are the Currie performance forged alloy 35 spline axle shafts that feature the stock Tacoma 6 lug wheel bolt pattern and stock diameter register hub for proper brake drum indexing. Axle kit features wheel studs installed, Tacoma axle bearings, bearing retainer rings, and oil seals.
The only parts needed to complete this unit is a 9" high or low pinion 3rd member. Nitro Gear & Axle offers two perfect select options to complete this great upgrade. The same USA Made Billet 3rd Member case as our full competition Pro 40 Series, but this one is assembled with a street-able gearset and can be used with the standard 31 or 35 spline air locker. Or if the budget requires a different approach, as an alternative option, Nitro Gear & Axle also offers a Ford 9" 3.250" Premium Performance Nodular Iron Dropout 3rd member. This F9" Nitro housing is made of high strength Nodular Iron, with stronger Forged Steel Caps, 5/8" Grade 8 Cap Bolts, and Billet Adjuster Nuts for added strength. Rated to 1200hp. Either combination makes this exclusive upgrade more affordable and long lasting for vehicles driven on and off the road! Great for popular aftermarket upgrades on Jeep TJ, JK, Toyota Tacoma, etc. Designed to hold up where the factory rear application may not, Heavy Overland equipment vehicles, over-sized tires, etc.
Both Nitro 3rd member packages include a Ford 9" ARB 99 Air Locker! The advantage of the ARB Air Locker lies in the pneumatically operated locking system inside the differential. When activated, the Air Locker prevents the differential gears from rotating and therefore prevents the axle shafts from turning independently of each other. With both wheels tied directly to the rotation of the ring gear, the vehicle maintains maximum possible traction at all times. When unlocked, it operates just like a conventional 'open' differential. We recommend using one of the three ARB Air Compressors available.
Toyota Tacoma F9 9"
Make your selection today!
Please contact us with your specific questions and inquiries.
LINK BELOW:
http://www.justdifferentials.com/ProductDetails.asp?ProductCode=NPHTAC-F9
Fits:
2005 & Newer Toyota Tacoma
Differential: F F9" up-grade
Gear Ratio: 3.70, 4.11, 4.30, 4.56 & 4.86
Manufacturer: Nitro Gear & Axle
This Product can ONLY be shipped VIA Freight Truck.
For orders placed outside the Continental USA, call Just Differentials 866-349-6801 to receive ship quote and place an order.
Tech Note: Includes 35 spline axles. Re-use OE brakes, w/ABS or wo/ABS.
Required selection options:
Ford 9" Nitro Billet Aluminum 3rd Member REBF9BILLET-ARB-35 or Ford 9" Heavy Duty Nitro 3.250" Nodular Iron Drop-Out HousingNPDOF9-2-325
3rd Member includes a Ford 9"ARB 99 Air Locker ARB-RD99 & Ford 9" Nitro Ring & Pinion F9"
Optional selection options:
Wider for Long Travel Truck
Front Differential:
Matching Ratio w/Open Differential
Matching Ratio with ARB Locker
Front Differential:
Recommended selection options:
ARB Air Locker Compact Air Compressor ARB-CKSA12
12V High Output ARB Air Compressor ARB-CKMA12
12V Twin Onboard ARB Air Compressor ARB-CKMTA12
