brett76 said:
thank you very much. hopefully hell chime in here too'
or anyone else who might know
David is the expert here, but I'll tell you what I did. I did replace the front output shaft support bearing, It was easy to drive the old one out and easy to drive the new one in. There is a c-clip to hold it in place, be careful with that.
You need a big press to get the old output shaft bearings off, then a tiny pilot bearing puller to get the tiny pilot bearing out of the front of the output shaft. To re-install the bearings on the out put shaft, you also need a big press. I tried a bearing puller and had no luck. You need a big press.
Once the new bearings are on the output shaft, it is time to reassemble the case. Be careful with the high low shift fork. It is easy to get the actuator in wrong. Once the whole case is back together, the last job is to set the preload on the output shaft bearings. The retainer that holds the outer race has a small shim under it. This shim, determines preload in the whole system. I was given David's advice, that 9 times out of 10 the old shim will work and get preload correct. My experience was different. After install, my preload was zero and there was slight play in the shaft. I ordered a full pack of shims from Cruiserdan-I think there are 12 and they are $7 each.
By trial and error, I got the right preload after 3 tries and an educated guess. There is no shortcut here. You assemble, measure preload, and if wrong, drive out the race/shim and try a different one. If you are methodical it goes well. I have almost 5000 miles on my rebuild with no issues, so I think I did it right.
Good luck, doing a second case would be easy. Doing the first case was difficult. I took my time and did everything as right as I could. The output preload adjustment is not especially hard, but it is tedious, and the result has to be exactly right, or the work of the rebuild was wasted.
