- Joined
- Feb 26, 2003
- Threads
- 200
- Messages
- 1,807
- Location
- Sherwood Park, Alberta
- Website
- fawcusfitness.com
Hi there,
Ok I have two CT-26 turbos, the one in the truck now is from the MR2.
I want to take the supra exhaust housing and put it on the MR2 so that it will mate right on the 13BT manifold.
To switch housings do I just undo the strap in the middle of the turbo and then pry the housings apart? And then the reverse to install on other turbo? Can I change the positioning of the exhaust outlet so that it is turned in the direction I want it (that called clocking?)?
Just want to make sure I don't wreck anything!
I could just use the CT-26 from the supra but I understand that it is too large, although I know there are one or two here using it. Also I know the MR2 turbo works well so I want to stick with that for now.
Thanks everyone for your input.
